Which center for Dyna 52's
Username: Blazer
Post Number: 65
I just purchased Dynaudio 52's to use as the front mains and was wondering which center to consider. The 122c or 42c? Thanks for your input!
Username: Eld
Post Number: 9
Blazer,
Since the center does a huge amount of work in a surrond system, I recommend getting the 122c.
Username: Allen
Post Number: 11
If you use HT most of the time then get the 122c.If your main concern is two channel music then the 42c is fine and you can still save some money.
