DVD+ and DVD-
Username: Tim
Post Number: 18
A friend is about to buy a DVD burner for his PC but doesn't know whether to go for a DVD+ or DVD-.
His DVD player is a Sony DAV550 system and he wants to be sure anything he burns will play properly.
Any advice?
Username: Project6
Post Number: 80
dvd + has the ability to be divided into chapters and is compatible with a lot more DVD players than a DVD-
there is a good product on the market called DVD xcopy platinum...the gold version is the lowest i would go for. any way this product can actually duplicate (macrovison encoded) dvds
Username: Falp
Post Number: 22
I have the same problem.
I'm asking a friend to copy a fez DVD movies on a PC DVD recorder and don't know wish disc to buy, -R ou +R...
Need to Register?
Forgot Password?
Enable HTML code in message
