Pioneer Deh-P6500 Problem
Wheels
I purchased the deck a while ago and it worked fine for a good 4-5 months. Then all of the sudden, I turned it on and the volume would not change down or up. It was stuck at a certain level. I proceeded to remove the entire deck and unplug the main power source to try to "reset the deck" as I was told. Now the deck will not even turn on at all. Any help?
YES; Trade it for a hooker. They are just as reliable. Check for a warranty bro. Get a new one. >>>>>>slurpee_machine@msn.com
Need to Register?
Forgot Password?
Enable HTML code in message
