Do i really need one?
Username: Smiley777
hi all
i recently bought a new system. I have a onkyo 901 with polk audio rm 20 and polk rt8. Do i really need an eq? my friends told me it would sound better with an eq. thanks
Username: Visiblehands
Calgary, Alberta, Canada
It depends. I like everything "original". Having a eq would certainly distort the music as any filtering system ultimately damage the signal path. Polks are on the bright side. Match eletronics carefully.
Username: Dmwiley
Post Number: 403
Short answer: no. Might it prove useful? Depends on your listening preferences.
Username: Eramsey
South carolina United States
Post Number: 103
All eq's will add some amount of distortion to the original signal. That said I would avoid them.Like David said match speakers and components carefully. E.Ramsey
Need to Register?
Forgot Password?
Enable HTML code in message
