DAC - use that of cd player or that of A/V receiver?
Username: Ipsofacto
New Delhi, Delhi India
This is a sort of a general (maybe elementary) questiion but I require help.
If not wrong, I believe both CD players and digital A/V's have DACS. If I use that of the Cd Player, then should I bypass that of the A/V and connect to the speakers through anolog outputs? Or channel the digital output of the CD player to the Receiver and use its DAC? Or is all this not neccessary and the AV circuitry will recognise the incoming signal?
This depends on the CD player/AV receiver u have.if u have a good DAC(24bit/192khz or above) on CD player itself u can just use ur analog out and connect directly to ur amps.if not use ur AV receiver.Again if ur much interested listening music don't connect to AV rec,since they r not much musical.better 2 have a stereo amp 4 listenin 2 music
Username: Ipsofacto
Thanks greatly Anonymous!
I am about to install a NAD C521 CD Player. The specs dont menntion 192khz or higher but the Analogue Converter is a Burr-Brown Sigma-Delta 20 bit Digital. I have a McIntosh C504 (pretty old) stereo preamp connected to a Yamaha power amp for regular listening. Alternatively I have a digital Onkyo A/V for DVDs etc. I guess your recommendation is still a good one for the NAD.
Username: Natish
India
NAD with Mcintosh is ok.I beleive yamaha amp u r mentionin is not power amp,but a integerated amp.
Need to Register?
Forgot Password?
Enable HTML code in message
