Amp information overload
Username: Mpatfb
Trying to pick the right amp to go with 2 10" Fosgate Type 2 subs 200 RMS @4ohm, 400 max. Plan to wire them in parallel for 2 ohm load. Mono or two channel amp?, exactly 200 RMS amp or do I fudge up a little? Do I divide amp wattage by 2 if using 2 subs? Looking at SPL CRM8202 (2X230 RMS @ 2ohm) am I barking up wrong tree?
Need to Register?
Forgot Password?
Enable HTML code in message
