Unlock ps2
Username: Jmh2004
Post Number: 38
is there a way i can reset my ps2 it has a parental code on it.. i found the ps2 ai plugged it in and it works but i try to play dvds and they dont work.. games work fine.. please help
Username: Project6
Post Number: 11231
Can't you contact the previous owner?
Username: Jmh2004
Post Number: 39
i dont knw them the house i found it at is empty....
Username: Jmh2004
Post Number: 39
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 9334
stolen???
Username: Project6
Post Number: 11256
LOL
Username: Jmh2004
Post Number: 40
naw... it wasnt stolen
Username: Gamerdude
Ontario Canada
Post Number: 197
go to sonys site and go to the ps sectiona dn FAQ for ps2?
Username: Jmh2004
Post Number: 41
alright thank you
Username: James06
hi there i need help on how to fix a ps2 pad so if u can help me well plz help me
Username: Prettyboy0123
Arlington, Texas United states
dang all my games i gotta name them prince of persia the two thrones,nba live 07,devil may cry 2,devil may cry 3,devil may cry 1,true crime new york city,def jam fight for new york,tekken 5 all them won't work and they all kinda new and im getting kinda mad ima break this ps2 it will play but when it do it goes to the browser screen or it will say disc read error some one help me please by the way i have a ps2 slim
Username: Basshead86
Chrome Dip it & Ship i...
Post Number: 8368
t.e.s.t.i.n.g.....
Chrome Dip it & Ship...
Post Number: 8391
testing...again
Chrome Dip it & Sh...
Post Number: 8392
1///2///3///:-)
Post Number: 8393
ok...last time
Username: Crayola0
Wisconsin
Post Number: 1415
wtf muddy..lol
Username: Jmh2004
P. A., Texas
Post Number: 54
Testing what?????
Username: Nicdan
Post Number: 8
Hi, Depending on the mod chip that is installed in your PS2 this may work: To play "genuine" PS1 or DVD Movies (hold the reset button from the off state - (red light on), until the blue light comes on. The PS2 should stay in this mode until it is turned off).
To disable the mod chip: hold the reset button in from the off state (red light on) for 5 seconds. this works with mine, good luck
Username: Skeletonrobot
i bought my ps2 used, so i had this problem. the only way i found to fix it was this:
# Turn off parental lock
Insert a DVD. When the movie starts, press Select to go to the menu. Find the "Setup" icon and select it. When in the setup menu, press Right(2) to get to the custom setup. Go down to "Parental Control" and press Right to go to "Region", then go down to go to "Level". You can now turn the parental control on or off, and/or change the password.
# Change or delete parental lock
Press Start when prompted to enter the code. Once you get to where you enter the numbers, press Start and you will be asked if you want to delete it. You can also enter another code instead of deleting it. The master code is 7444. Enter it, and at the last "4", press Select at the same time. Do this again, and you will eventually get the option to delete the lock. Enter 7444 again to delete the code.
Username: Jmh2004
P. A., Texas
Post Number: 72
hey thanks man that actually worked and it worked great, now i can watch dvds on it..
Username: Big_edge_head
Milwaukee, Wisconsin USA
Post Number: 418
bump
A pic is worth 1000 posts!!
Post Number: 9263
Bumpity bump bump
Username: Siva_almighty
Hi ,when I start my PS2 with DVD movie init, it doesn't even start. It always go to the explorer page and I can't proceed from there. Can you please help me with the steps for watching DVD videos in PS2. I haven't watched a single movie in PS2 tildate. Thanks in Advance.
Need to Register?
Forgot Password?
Enable HTML code in message
