Xbox live
Username: Thump510
Oakland, Ca U.s
Post Number: 88
how do Ihook up the cords and wat do i hook them up to?
Username: Project6
Post Number: 15866
Have you read the instruction manual?
Username: Flyingleaf
Post Number: 21
Yes the instruction should have covered that.
Username: 3dges
Compton
Post Number: 43
For xbox live all you need is a Ethernet cord going from a Router into your Xbox or you can also get the wireless network adapter but that can sometime cause lag when playing online
Username: Bum_drummer
US
Hardwire Is most definately the way to go with xbox Live. A lot more reliable
Username: Msand951
San jacinto, Ca Usa
Post Number: 200
what fred said
But if you have wireless router and dont want to buy the xbox wireless adapter . i hooked up my xbox to my laptop with the ethernet cable and it worked.
Username: Domenico
Glendale, AZ USA
Post Number: 104
you can hook yr xbox into a laptop that has a wireless connection to it and you had a steady connection?
Username: Doliga28
how to copy xbox-games?
i don't know and i have try al lot of programs!!
copy xbox 360 games _ how to copy xbox 360 games
Need to Register?
Forgot Password?
Enable HTML code in message
