X-box in the car
Username: Sekile
Zagreb, Tresnjevka Croatia
i connect my xbox in car with 12v/220v converter. I have problem because i have noise in speakers and bad picture on LCD. but when I connect converter to the other battery everything is good. What is problem? Is there any kind of protection for this kind of problem
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 1667
i have a 550 running my ps2 in my car and no probs, may u need to get a bigger converter
Username: Sekile
i have 300w inverter but it works fine on the other battery whitch is not connected to the car instalation. problem is in the instalation but i dont where
little man
I have a portable dvd player. how do I hook up my xbox to the dvd player.
Username: Project6
Post Number: 5243
Checkyour dvd player for audio and video inputs. If it does not have any, you can't.
Need to Register?
Forgot Password?
Enable HTML code in message
