Keyboard shortcuts
Username: Appleiphones
United States
can anyone send me keyboard shortcuts of MS-Word-2003?
Username: Djsmith
Post Number: 503
http://support.microsoft.com/kb/290938
Username: Warnerbob18
copy-> Ctrl+c
paste-> Ctrl+v
close-> Alt+f4
new-> Ctrl+n
save-> Ctrl+s
open -> Ctrl+o
cut ->Ctrl+x
Undo -> Ctrl+z
these are most commonly used shortcuts while working on office.
Username: Project6
Post Number: 16147
It's been almost a year. i sure hope the OP found some answers by now.
Username: Antennas
Post Number: 11
Thanks for this link its very useful.
Username: Rjs9163
Ctrl+a= select all
Ctrl+s= save
Ctrl+v= Paste
Ctrl+C= Copy
Ctrl+z=Undo
Ctrl+y=Redo
Ctrl+x+ cut
Ctrl+p= Print
Ctrl+w= Clsoe The document
Ctrl+f4= Exit Word
ctrl+e= Centre Align
Ctrl+L= Left Alignment
ctrl+R=Right alignment
Username: Rsuman1991
you can easily find keyboard shortcuts of MS-Word-2003, 07, 10, 13.go here https://support.microsoft.com/en-us/kb/290938
Username: Rogerafrance
CTRL+SHFT+SPACEBAR-Create a no breaking space.
CTRL+HYPHEN-Create a no breaking hyphen.
CTRL+B-Make letters bold.
CTRL+I-Make letters italic.
CTRL+U-Make letters underline.
CTRL+SHFT+<-Decrease font size.
CTRL+SHFT+>-Increase font size.
CTRL+SPACEBAR-Remove paragraph or character formatting.
CTRL+C-Copy the selected text or object.
CTRL+X-Cut the selected text or object.
CTRL+V-Paste text or an object.
CTRL+Z-Undo the last action.
CTRL+Y-Redo the last action.
Need to Register?
Forgot Password?
Enable HTML code in message
