My computer gives the following error code: NMI: Parity Check/ Memory Parity Error and NMI: Channel Check / IOCHK
Username: Matheri2000
Hi, My computer gives the following two error codes: Hardware Malfunction - NMI: Parity Check/ Memory Parity Error and NMI: Channel Check / IOCHK - System has halted.
I have visited numerous forums with this issue and tried all their suggestions but none has worked. Does anyone know how to fix this problem?
I have tried the following possibilities;
1.) I have replaced My RAM stick.
2.) I do not use any external graphic card so i didn't have to unplug any
from the mother board.
3.) I have removed all extension cards from their slots.
4.) I have tried with a different Hard Disk.
5.) I have replaced My CD-Rom.
6.) I have tried restoring the machine to default settings by removing the
CMOS Battery from the motherboard for over one hour.
7.) I have even tried with a different processor of the same family.
I have tried all these and none of them has worked. The error code still persists. The Hard disk, the RAM and the CD-Drive are all being recognized but the computer won't let me format it because of the above error code. This problem came about last week when I was repairing my OS. Can anyone suggest something? My motherboard is Compaq and I was using XP SP2 OS. Thank you in advance.
Username: Reallooker
http://support.microsoft.com/kb/315223
Need to Register?
Forgot Password?
Enable HTML code in message
