Mass DVD storage
Username: Toolfan23
Okay, here's what I want to do. I have a large DVD collection, about 600 and growing. I would like to lose all the discs and just have them on hard drives hooked up to my TV. What is the easiest and most cost effective way to do this? I don't want cables across the room from my computer. A barebones pc attached to multiple hard drives using the TV as a monitor? What's the best storage? I figure at least 2TB expandable with some kind of parity drive so I can't lose anything. I don't know too much about RAID drives or servers or anything. Willing to spend upwards of $2k if I can stop burning movies to disk. Any suggestions? I've spent hours looking into this but can't put my finger on the best scenario.
Username: Samijubal
Post Number: 3525
You might want to check out something like this.
http://www.avsforum.com/avs-vb/showthread.php?t=736151
Username: Toolfan23
Thanks David. That adds a whole different spin on my idea. So with that dvr/dvdr combo you can put a dvd in and copy it directly to the HD? and then play it through the dvr?
Username: Samijubal
Post Number: 3528
Probably not a retail DVD. A recorded DVD, yes.
Username: Rainnaunseque
Post Number: 19
no need
Need to Register?
Forgot Password?
Enable HTML code in message
