Help With Finding a Sound Card
Username: Edgylemon
Hi-
I'm new at this and having trouble finding a sound card... I have a multi-track cassette deck that I want to connect to my music software (PC). So, I guess that means I need a souncard that has an RCA input, but it also has to be external (I think) because I use a laptop. Any ideas on this? I've been searching online and not having much luck. Thank you!
Username: Project6
Post Number: 13571
Put "Digital Audio Workstation" in a search engine and go from there.
Username: Edgylemon
Thanks~ I probably don't have too much money to invest in a whole new set up - since I already have recording software on my PC, is there any (fairly) cheap way to bring the 4-track recordings into my notebook PC software?
Someone mentioned I may be able to use a DI box (which would probably require a series of adapters). Any thoughts on that? Or if there is an existing compatible external soundcard, that would be better....
Thank you!
Username: Project6
Post Number: 13574
I feel your pain...
Define "fairly cheap"...multi track audio is hard to edit on the cheap. You will need ASIO support with that sound card.
Go here for more info
http://www.soundblaster.com/resources/read.asp?articleid=53937&page=1&cat=0
Username: Wavfile
Boston, MA USA
Deb, You prob will need an audio interface that has RCA ins and outs. Be aware that not all will have those so you will have to research. Also, bringing the 4 tracks in should be fairly easy as long as you have the right software. Most allow importing tracks in as long as the formats are matching. Be sure that it IS an RCA connection. Audio interface's vary wildly in prices depending upon the number of ins & outs and capability. Here is a list to start with:
http://www.cakewalk.com/Tips/audiohw.asp
at least you can get the specs on some of the more popular cards and links to their sites. Hope that helps
WavFile
Username: Mark007
i want to a sound card for mine new cell N80 which one is best ...colud you please help me out ...
http://www.hanovercompanies.com
|http://www.newcondosonline.com/pennsylvania-condos/philadelphia-new-condos/
Username: Andreas
Post Number: 28
The sound blasters are the best value USB cards for recording casettes onto computer. This one would be probably the best:
http://www.creative.com/products/product.asp?category=1&subcategory=207&product= 15911
Username: Wavfile
Boston, MA USA
Post Number: 8
keep in mind to do ALOT of research as each one is going to have its own pros & cons, and you've GOT to read everything u can possibly find- and then read more on it.
Need to Register?
Forgot Password?
Enable HTML code in message
