Audigy Gamer (SB0090) Grounding problem
Username: Clearflow
I have been searching all over if there is a way to fix the grounding problem with is card. When the computer is turned on, a loud pop happens suddenly. Plus, if you touch anywhere on the computer case with something metal, you can hear it like you would be scraping the speaker plug on the case itself through the speakers. So I know there is a grounding issue with this card but is there a way to fix it? Its still a great card but I don't like a product that doesn't have a ground to it.
Need to Register?
Forgot Password?
Enable HTML code in message
