BernyMac's audio build from beginning to the end
Username: Bernymac
AQ HD3!!, CA United States
Post Number: 1130
I know most of you have already seen the pictures I posted in the past. But I wanted to post them up again from beginning till the end. Right now I'm somewhere around 50% done, so theres still more from just what I have of the pictures.
List of equipment:
HeadUnit: Pioneer P860MP
Subwoofers: 2* AudioQue HD315
Subwoofer Amps: 2* MassiveAudio P3000.1
Components: CDT HD-62/M6 Front and Rears
High Amp: 1* MassiveAudio P800.4
Alternator: 260AMP Iraggi Alternator
Batteries: 1* Optima Redtop (under the hood) / 2* Odyssey 2150S (Cargo Area)
Subwoofer Box: Designed by DJ, Built by me.
Subwoofer Box Specs: 14cuft after subwoofer displacement and port, tuned to 40hz.
Now on to some old pictures.
Next update will include pictures of the inside of the box resined. and 90degree angles of resin.
After that, carpet the box, then sound deadener, and then finally install everything. Should be done before the end of the year, but don't count on it. Lazyness kicks in from time to time.
Ok, now old pictures.
Username: Bernymac
Post Number: 1131
More pictures of the sub's when I got them. Beginning of October.
Went and got the wood the next day to begin on the box.
Username: Bernymac
Post Number: 1132
Putting the box together and cutting out the hole for the subwoofer.
Test fit.
Double Baffle glued and complete.
Username: Bernymac
Post Number: 1133
So I created the brace that will hold the box together inside, keeping it from flexing. Don't worry, at this point in time I did a little more bracing than that.
Added the top piece to the box. Pain in the A** when trying to build this box by yourself. And also having no table to work on is a pain.
Username: Bernymac
Post Number: 1134
So now, these pictures were taken on 10/25/06. And at that point in time the box was put together. Heres those pictures.
Username: Bernymac
Post Number: 1135
Contined from last post.
That was the last update. A week or so later I resined inside the box every 90Degree angle there was, didn't really take pictures of that. Today, I poured in fiberglass resin on the flat surface, about 3/8ths thick or so. Pictures tomarrow on that, not sure if thats interesting but I will post it anyways.
Fi AudioBTL
Post Number: 7405
nice work berny.
you have til jan 27 to get ready. thats when the next comp is.
Username: Rovin
Trinidad & T...
Post Number: 10005
NICE ! - i bet its gonna be super loud
3/8" thick resin u say !? - isnt that a bit too much & by u adding so much will decrease a lil bit of ur overall box vol ......
Username: Matt12490
The biggity biggity BAY, California USA
Post Number: 1448
14 ft. ^3 is HUGE for 2 15s!!
Username: Bernymac
Post Number: 1137
well that was a estimate of how much resin i put in. Probaly its like more or less than 1/8ths.
Username: Bernymac
Post Number: 1143
Todays Update as promised. The resining part of the box. I have one more side to go and about a few more corners to do as well. Enjoy peoples!
Username: Gh0st_31
Brooksville, FL USA
Post Number: 26
sweeeeeeeeeeeet
Username: Stnorris
Davenport, IA US
Post Number: 1811
loooking good
Username: Bernymac
Cambodian
Post Number: 1412
edead install. its only one picture but I'll see sup tomarrow one what I decide to do.
Fi AudioBTL
Post Number: 8228
nice.
Username: Bernymac
Cambodian
Post Number: 1573
Heres some more progress pictures!
Username: Bernymac
Cambodian
Post Number: 1574
More Progress.
Username: Bernymac
Cambodian
Post Number: 1575
Box fits perfectly into my car. Its goes in nicely and will snug between my panels nicely as well. Also window height length which is really good.
Username: Mr_kebo
Albertville, Al USA
Post Number: 899
where did you get those massive audio amps? What kind of power do they put out?
Username: Drsmith
Montana USA
Post Number: 2346
low hz.com is where he got them, they do rated 3k at 14v and 2600 i think at 12.5
Username: Bernymac
Cambodian
Post Number: 1586
Alright, heres more updated pictures of just some wiring and the amps on the back seats. and don't trip, I cleaned up the wires some, but their so thick its hard to bend them and have them placed how I want it. I'll take more pictures today.
Username: Bernymac
Cambodian
Post Number: 1587
Fused the front batteries.
Edeadv1SE^2, then edead v3, then edeadv1SE^2 again.
The doors and comps are the last thing I'm worried about at the moment, more progress on these in the next week or two.
Username: Thecrypt
Post Number: 58
I accidentally put my thumbs so far up that I broke them
Username: Tdbdadrummer
Wellsburg, WV USA
Post Number: 1812
I hate to sound stupid lol, but what kind of subs are those? I was going to guess DD?
Username: Bernymac
Cambodian
Post Number: 1592
AudioQue HD315
Username: Bernymac
Cambodian
Post Number: 1593
alright some more pictures.
Username: Bernymac
Cambodian
Post Number: 1594
Now to the bad....the holes.eh.
Username: Bernymac
Cambodian
Post Number: 1596
Username: Sploosh56
Ohio
Post Number: 1592
put some clear silicone on it. the system looks awesome by the way. that sucker is going to hurt when it gets bumpin'
Wellsburg, WV USA
Post Number: 1828
How'd you get holes in those?
Username: Teddy21
Ann Arbor, MI USA
Post Number: 348
Very nice install....you wanna come install my next system for me?
Username: Mr_kebo
Albertville, Al USA
Post Number: 945
can you upload those resin pics again?
Username: Bernymac
Cambodian
Post Number: 1615
Will Do Mr. Kebo. Just give me a minute.
Username: Bernymac
Cambodian
Post Number: 1616
Resining REPOST:
I poured my resin in, f@ck brushing it on! Chad Lee know's sup with that.
Username: Johnfiac
IL Afghanistan,...
Post Number: 900
ewwwwwwww good thing the inside of the box isnt there for looks lol that sux about the hole in the sub :-( but nice install
Username: Johnfiac
IL Afghanistan,...
Post Number: 902
Username: Johnfiac
IL Afghanistan,...
Post Number: 903
ooops my bad btw thats a big @ss porthole stick ur head in there when doing some test tones ;)
Username: Stnorris
Davenport, IA US
Post Number: 1941
very nice...looks like a lot of work.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 10909
the bragging area is always down..this is the first time im seeing this...Good work man....
Username: Stnorris
RE SX 15, IA US
Post Number: 2059
clean that box up with a nice paint job or some carpet and post some pics.
Username: Imalik
Jackson, New Jersey Ocean
Post Number: 98
Real nice set up.
Username: Bernymac
Cambodian
Post Number: 2124
I plan to spray bedliner on it. I'll do so once my parents are ok and won't need as much $$ from me. This thread isn't closed yet since theres still more stuff to do. Money is just to tight at the moment. And thanks Malik. =).
Username: Mike_16
Burlington, Wisconsin Us
Post Number: 244
why is there 2 power wires in those amps or is it a power and ground wow what a dumb ? huh lol well it looks lik etheres 2 remote wires in the one amp whats that 4? wow would get lost with trin to hook up a big three with all those power wires i wouildnt know where to start
Username: Johnfiac
IL Afghanistan,...
Post Number: 1678
Connecting power isnt hard, just takes time to run them all through the car\firewall the 2 in the remote i would guess is so he didnt have to run another remote wire so he daisy chain'd it to the other amp, berny.. by looking at the amp... it looks like there are 4 terminals for speaker outputs its mono so i am assuming that thats just for making it easier to run in paralel, are those DVC 2ohm running 1 ohm, or DVC1 running .5?
BTW where the fu<k can i find resin.... i looked all over at menards and homedepot.. kept finding like varnish and wood polish stuff.. nothing like that at all...whats it called exactly?
Username: Bernymac
Cambodian
Post Number: 2138
its called epoxy resin, and its in the paint section. it should be near where the bondo/gorilla glue/wood glue isle. and its not two power wires. one ground and one power. if you looked close enough you can see the black electrical tape to show that its for ground. and like killa said, i daisy chained for the remote. on another note. the subs are dual 4. wire down to 2ohm each, and connected to its own terminal at 2ohms giving them about 1000rms each. the amp is 2ohm stable (bridged). but since the other amp doesn't work. i just hooked it up as you see. the amp isn't 1ohm stable. a lot of people get confused as to why i hooked the subs the way i did. lets just say i know what i'm doing and no! i can not wire it down to 1ohm bridged!! so yeah.
Username: Mike_16
Post Number: 264
ok i understand i wasnt thinking of of chaining the power wires lol forgot, but anyways nicee setup
Username: Gamerdude
Ontario Canada
Post Number: 429
How thick is the surrounds on those woofers?
Its gotta be up there 1-3mm?
Username: Bernymac
Cambodian
Post Number: 2658
I thought I would update this thing and post up a few more pictures of some progress.
Building a amp rack for the amps and also made a rack that goes under the 2nd row seating to hold the AC EQX and 6XS.
Username: Bernymac
Cambodian
Post Number: 2659
Now to the finished product!
Like this thread says, from beginning to end. And I am far from the end of this whole project.
I will post pictures of my new box in the next day or so. And a few weeks from this post, pictures of my custom door panels, done by me of course.
Username: Trey4sports
Post Number: 1134
very nice berny. i really think your gonna be a lot louder with a smaller box. is that a 150 i smell??
Need to Register?
Forgot Password?
Enable HTML code in message
