How do i connect my pc to Satellite?
learner
I have dell XPS generation4 media center pc
wintv pvr usb
I can watch the cable tv through my wintv which is already hooked upstair, but i want to watch satellite at the same time.
i have progdvb installed into my pc.
how do i hooked up my satellite reciever to cable tv outlet next to the wall and then probably get the signal through to my wintvpvr usb
please help me on this
thank you
Username: Hannjeff
Halifax, Nova Scotia Canada
Post Number: 62
You take the coax out of your reciever, and plug it into teh coax of your usb pvr. Its that simple. Your never going to be able to change channels from the pc, or access the menue, you will still need the reciever for that, and you are in teh wrong form silly.
Need to Register?
Forgot Password?
Enable HTML code in message
