I'm a noob here. Pics of my home theater.
Username: Phreak9i6
First the specs:
-Panasonic 50" Plasma display
-Denon 2805 A/V Receiver
-Panasonic progressive scan dvd player
-Kenwood 6.1 surround speakers
-XBox
-Playstation 2
-Just picked up an InFocus ScreenPlay DLP SVGA Digital Media Projector for misc use.
On the UPS Truck:
-Infinity Beta 50 Fronts
-Infinity Beta C360 Center
-Infinity SW-12 Sub
Future:
-Infinity Beta 250 Dipole rears
Link to pics:
http://www.kenandkarinwilliams.com/gallery/hometheater
Username: Project6
Post Number: 3519
Nice!
Those lights coming out the window right above your cabinets...don't they bother you when watching the TV?
Nice cabinets!
Username: Phreak9i6
My wife picked out the cabinets (and the plasma was her idea), The sunlight comes through the window from 2pm-4pm Im usually not home to notice, otherwise its really nice. The cabinets have those "touch to light" hinges.
Username: Matt1234
How did you get your wife to accept the idea of adding tower speakers down the road, Ken? I also noticed something else about your living room, however. You have a ceiling fan. How is that fan of yours able to withstand the wraths of your home theater's subwoofer without falling off the ceiling?
Username: Matt1234
Cool system, though.
Username: Joe_c
Atlanta, GA
Post Number: 1014
Look great man, can't wait to see it all done.
Username: Phreak9i6
Well. She hasn't seen the Infinity speakers yet. I'm going to go demo them for her tonight at the local CC. I'm not a bass freak so I dont turn it up past the point of needing it, and the ceiling fan is mounted decently.
Has anyone else had issues with ceiling fans and bass? I never took it into consideration before.
I'm pretty excited :-)
Username: Paul_ohstbucks
Post Number: 2108
You'll just have to hook everything up and see:-)
If the globes arent tightly secured, they might rattle which would be extremely annoying. It's nothing you couldnt fix though. If you play your movies with much volume, eliminating things that rattle will be an ongoing adventure. If I turn mine too loud, the walls will buzz all by themselves from the inside.
Username: Thx_3417
Post Number: 1076
Use the slow "THX" rattle test, this is a slow frequency sweep starting from 100Hz down to 20Hz, and you well be able to also identify other rattles or buzzing sounds that's not part of the soundtrack, this is a real slow process which can take a few hours to perform, and doing it at different SPL db levels....
Username: Camaro823
British Colu... Canada
Post Number: 180
Looks good man, love the tv
Username: Phreak9i6
had to add my HD Tivo was installed yesterday (finally!) looks even better now :-)
Username: Vbhutwala
Mumbai, Maharashtra India
Doesnt your plasma suffer from burn-in, since you use it for video games
Username: Vbhutwala
Username: Nemen
Trinidad & Tobago West...
Looks good man.
Need to Register?
Forgot Password?
Enable HTML code in message
