HDMI converter
Username: B_davis_68
HI i have a Mitsubishi rear projection tv model #WS-65809 and i want to hook up hd to the tv from my cable box but the cable box only has a HDMI port and the tv AV type ports for hd is there a converter for this? Thanks
Username: Bigwinw
Are the inputs for this TV are like the link below?
http://www.audiovideo-parts.com/ProdImages/935C957001.jpg
If so you want something like a HDMI to 5 RCA Component AV Converter
Username: Tofayel
Dhaka, Dhaka Bangladesh
Post Number: 10
Yes converters are available in market. You may check my previous post, HDMI to DVI Cables.
Username: Lauraedward
i think you need VGA Adapter to TV S-Video RCA Cable.This allows video output from your PC or laptop computer to any TV with S-Video or RCA video input. it is easily available in market. have a look on the following link. do you require this cable?
http://www.suntekstore.com/goods-10012077-VGA+Adapter+to+TV+S-Video+RCA+Cable+-+Black.html?&utm_source=forum&utm_campaign=18Upload
Username: Project6
Post Number: 16033
Do you work for the website?
Username: Aleenajoe
Nottingham , Nottinghamshire UK
Post Number: 8
Yeah the converter is available in the market you can check it in the market ...
Username: Steven_brooks
Post Number: 7
Hello Community,
VGA to HDMI converters are most commonly used to go from a computer to a TV that has an HDMI input. VGA is an analog signal so the converter has to convert the signal from analog to digital. Many VGA to HDMI converters also take an audio input and add that to the HDMI signal since HDMI does both audio and video, while VGA only does video.
Thanks and Regards,
Steven Brooks
Need to Register?
Forgot Password?
Enable HTML code in message
