Using US equipment in Australia
Matthew
I live in Australia and want to use home theater equipment from the US in Australia will a voltage converter do or would I need to convert the frequency as well from 50 to 60 hz? greatful for any input.
Username: Cried
Erie, PA US
No, it shouldnt be any different.
Username: Van_man
Boston South, MA
Post Number: 2499
Yes, Its quite diffrent. You use 220 over there correct? well that comes in the form of 50 hert cycles. Most step down converters will automaticly adjust to 60hz for US products. Yoe will need one of those heavy (Like 30 kilo) type converters
Username: Van_man
Boston South, MA
Post Number: 2500
Why am I replying to a 4 year old thread????
What?
Username: Mena
So old thread. But just want to say, for a world wide travel, I often take a power converter that provides 3 AC outlets, 4 USB ports and extra 3 plug adapters. You can find power converters 110V to 230v or 220V to 110V. It is much portable to use wherever you go. https://www.amazon.com/dp/B01E140XWA/
Need to Register?
Forgot Password?
Enable HTML code in message
