Cable I use to get Surround from my digital cable box?
Username: Reptilemk4
Hello, I am thinking of buying speakers to get surround sound with my digital cable box. I already have a receiver, I just don't know if my cable has surround capabilities... I have Rogers Digital Cable and a pic of the back is: Upload
I have a Yamaha RXV357 receiver and the back looks like:
The cable box has "digital audio output" but I'm not sure what cable I need...Is it a digital coaxial cable or digital optical cable. Thanks! :D
Username: Mike3
Wylie, Tx USA
Post Number: 1529
Digital Coaxial from you cable box.
Look at the Yamaha's Optical Inputs. If your cable box had an optical output it would look just like one of those.
You should check to see if your cable provider has a box with an optical output they can upgrade you to.
Username: Mheath8663
Post Number: 16
It looks like your cable box has a digital audio out connector. Its difficult tell from the picture but it looks like coax. If so, you need a cable like this
http://www.findacable.com/servlet/the-349/12ft-VELOCITY%3F-DIGITAL-AUDIO/Detail
I paid about $10 at Find A Cable
Oh alright, thanks for the clarification :-)
Need to Register?
Forgot Password?
Enable HTML code in message
