Is there a Differance between HDMI cables?
Username: Lonald77
I am picking up My HDTV tommorow, the cables in the store are very expensive for monster cable.
I found a site HDMICABLEZONE.COm which is much much less and is here in NY. there cables start at 5.50 where as monster cable was 90+.
Is there a differance is my question?
Username: Mheath8663
Post Number: 15
In my opinion, over short cable runs, there will no noticable difference in the expensive HDMI cables and the cheap ones. I don't know about the cables from the place you mentioned. I've used this one and it works great.
http://www.tekcable.com/2m-velocity-high-speed-hdmi-cable.aspx
However, if you have a long cable run, you may see some difference with a more expensive cable. They generally have larger gauge wire and more shielding. That said, $90 for an HDMI cable is still way overpriced.
Username: Lonald77
so, orderd from http://HDMICABLEZONE.COM
i got 10% plus $1.00 off there 4.50 flat rate shipping. Use code "cablezonefriend"
I ordered from them and got the cable within two days, they sent me tracking confirmation as well.
for 5.50 for there entry level cable and 8.00 for there mid grade you cant go wrong...
i got there 8.00 boxer cable, happends to be a nice braided cable...
I give them two thumbs up...
Need to Register?
Forgot Password?
Enable HTML code in message
