Coaxial audio question
Username: The_nickcheese
Ok heres the story.. I have an XBOX 360 hooked up to my 32" hi-def t.v. through the HDMI port. Everything was working fine then today I bought a Turtle Beach headset and I need to use the Audio Out connections on my t.v. but the only problem is that there is only a Digital Audio Out (Coaxial) option so I was wondering if there is a cable out there to connect the coaxial (orange end) to red and white ends? This may be a stupid question but I don't know and I've been looking but I can't find anything out.
Thank you very much for you help.
Need to Register?
Forgot Password?
Enable HTML code in message
