RCA to 1/8 Female
Username: Rusguitar
Floydada, TX USA
I've got a DVD player as my audio source. My video is going out to a projector, but I need to connect the audio to the speakers we have. The speakers have a 1/8 cable that wants to connect to the source, so I need to go from the 2 male RCAs to a 1/8 Female so that I can plug the speakers' male end into that female.
I hope that makes sense...
Anyone have a link to the correct cables I need?
Thanks!
Username: Project6
Post Number: 15665
Does your DVD player have speaker outputs? Are the speakers powered?
If not, you will need a receiver before you can connect them to the speakers.
But if you think they will work, try going to Radio Shack, they will have the connector you need.
Need to Register?
Forgot Password?
Enable HTML code in message
