PC Audio out to Mixer
Username: Urright
How to fix a huge Hum comes from mixer
when i plug analog to digital audio converter
from PC out to Mixer
Thanks
Username: Project6
Post Number: 16277
Which signal is analog?
That is usually a grounding issue. But with analog to digital converters, you may have a different issue.
Are you using a MAC for your music source?
Username: Urright
Hi Berny.
The analog signal out by my PC speaker out
and goes thur analog to digital converters
to My Mixer
The Hum is comes from my PC Speaker
Thanks
Username: Project6
Post Number: 16280
Let me get this straight. You are using the PC speaker output to connect to your mixer?
If this is the case, then your problem is right there. You do not want to use a variable high level output to connect to the mixer. You need low level outputs. You need a soundcard that has a stereo RCA output. Then you connect that to the mixer.
Need to Register?
Forgot Password?
Enable HTML code in message
