Home surge protection
Username: Tsl90
Edmond, OK United States
Post Number: 13
My local electric co offers a "Watts dog" which is a surge protector they place on the line going into the house. They guarantee protection and will pay for damages secondary to surges. I would pay a small monthly fee but rather than protecting just my audio stuff it would cover everything.
Anyone heard of this? Is it a reasonable idea?
Thanks
TL
J. Vigne
It depends on a few things. Does it matter whether your clock radio blows up? If you have home owners insurance you are probably covered if big things get damaged. There is a piece of mind issue but only you can answer that question. I would prefer a very good S.P on all my important equipment. Check for R.F.I. and E.M.I filtering on this device and compare specs to something like a PanaMax.
Username: Tsl90
Post Number: 16
Thanks for the help. I got some info in the mail today and it doesn't seem worth it.
Do you recommend any particular PanaMax model?
Thanks
TL
J. Vigne
Buy the best you can afford. they all respresent great value.
Hey you all might be able to appreciate www.kevinkringle.com My friend said it's great. I am going to check it out.
Need to Register?
Forgot Password?
Enable HTML code in message
