New Forum Features Debut
Moderator
Username: Admin
Post Number: 3541
The message board has been updated with the following new features:
  1. Sortable columns
  2. "Create New Thread" Button Added (replaces text link)
  3. Color coded member status (gold, platinum, etc...)
  4. Slightly revised login panel/box.
  5. Slightly revised "add message" form
  6. Some font changes
  7. "Forum Search" button added to top header
Still to come:
  • Edit and Print Icons next to each post
  • Betting looking icons
In the works:
  • Avatar or image upload within profile/post
  • Report abuse link/icon in each post
Username: Ska
Post Number: 719
thank admin for the abuse and avatar... that will be awesome:-)
Username: Nd4spd18
Northwest PA
Post Number: 6818
Yeah, those faetures and the edit button will be really nice. I liked the older fonts better though the new ones are too small.
Moderator
Username: Admin
Post Number: 3556
Are all fonts too small or just some of them. Can you be more specific?
Username: Nd4spd18
Northwest PA
Post Number: 6843
All fonts look smaller to me, the post text and the user info column to the left. It makes everything very hard to read on my 1600x1050 resolution screen, unless I use my browser's zoom.
Username: Ska
Post Number: 730
yes admin, the faunt is a little smaller and i can understand how it is hard for some people to read. before it was kinda bold now its very thin and almost smaller than the normal lettering in the threads
Username: Nino_gatto
Ho comprato la macchina e non ho il codice il modello � un Concert M4
4B0 035 186 C
MADE IN PORTUGAL
7 648 247 380
Grazie per l'aiuto
Need to Register?
Forgot Password?
Enable HTML code in message
