Help with ipod's
dose anyone know how to take vidos off my computer and put them on my ipod???
Username: Project6
Post Number: 4741
Do you have the instruction manual or PDF for your iPod?
Username: Confuzed_simon
Plano, Texas USA
download a free program, look under ipod help i have the websites on there to do so for free!
Plano, Texas USA
Posted on Wednesday, January 11, 2006 - 01:28 pm:
to, i want my movies, there is a free tool http://www.videora.com/en-us/Converter/iPod/ here, all you have to do is select the source of the movie and it will convert it to play on your ipod.
if your dvds are copy protected (bought dvds) you will need a program named any dvd (http://www.slysoft.com/en/anydvd.html) you can get a free 15 or 21 day trial, also if you want to keep the program get a patch from somewhere, tho that is not legal, so i would just use the trial and buy if you want, and that should be all you have to do since anydvd works with the ipod video converter, happy converting
confused simon
there si the orignal post, if need more help email me and ill see what i can do
