Editing sound files, removing "lyrics" from a song...
is it possible to remove the words from a song so its an instrumental song. I want to remove words on a rap song so its only instrumental but im not sure if its possible, ive looked around and can't find anything....
i want to do the same but i dont think you can try downloading an instrumental version
i have just found a program which does what you need but you have to buy the software dont know if that helps - its called Vogone do a google search and it will come up
