THX cinemas in the USA and world wide what do they sound like...
Username: Thx_3417
Bournemouth, Dorset United Kingdom
Post Number: 212
Tell me about the THX cinema you go to, I like to hear feedback on the name of the THX cinema web site information about the THX cinema that you attend to often in your home town or city, which part of the auditorium do you sit in.
The best THX presentations the ones that you have felt really hard!
And what is, your memory like is it as razor sharp as mine so tell me did you or your girl friend like THX.
And which THX trailer can you remember seeing form the first time since May of 1983 Return of the Jedi 70mm Dolby stereo six-track to the present day.
And any THX 70mm presentations you have seen.
And do you take your SPL sound pressure level meters along for the Event to see just how high in technical terms the THX cinema presentation is just for reference proposes and for home THX presentation to see if you can duplicate the same Event at home on Laserdisc DVD and D-Theatre as well.
Thank you
The Audience is leistering...!
