Mosfets burning
Username: Badprop
Hi. Sitting with a weird problem with no known cause or fix. I've searched.
My startsound 4 channel amp suddenly burned the mosfet power supply (2 mosfets of 4). I replaced the all 4 mosfets, installed the amp and it was playing good. When I switched of the head unit the mosfets burned. I replaced the mosfets and removed the remote wire from the amp. I connected a bridge from +12v to remote and it turned on an it played good. When I removed the bridge the same mosfets burned again.
THe factory radio has a +12v out when headunit on so Im using that as remote turn on.
Does anyone have any idea what could cause this?
Regards
Need to Register?
Forgot Password?
Enable HTML code in message
