Locked blaupunkt 6-cd-changer
Username: Dewalddvs
please help. i have been waiting for a week and still radio display 'wait for 1 hour'
tried to replace with dvd player but controls on steering don't work
nissan micra 1.5 dci
6cd-changer
bp5387 7 1223022
7 645 387 318
can someone send me a code and what to do if no buttons work?
Username: Hay88
Post Number: 76
FOR ABOVE try code 7268 AND
BASIC INSTRUCTIONS TO ENTER A BLAUPUNKT RADIO CODE
Switch the ignition key ON
Press and hold AS button * and the ON button at the same time
Display Shows SAFE then goes to 10 - - - - with a "Beep" from the speaker
Press Preset Button " 1 "repeatedly until the 1st Digit of your Code is displayed
Press Preset Button " 2" repeatedly until the 2nd Digit of your Code is displayed
Press Preset Button " 3" repeatedly until the 3rd Digit of your code is displayed
Press Preset Button " 4" repeatedly until the 4th Digit of your code is displayed
If the display now shows the correct Code number then
Press Button AS and hold to Enter and if successful there should be a "Beep" from the speaker and the radio should switch on
Username: Orrstar
hi how do you put the code in for the cd player when it comes up safe thanks james
Username: Hay88
Post Number: 830
To give you some idea of how long you'll have to wait before you can attempt
re-entering the code if you do get it wrong:- (and by wait, that means having to leave
the key in the ignition, turned to position one, and the stereo switched on as well)
Attempt 1 - wait 10 secs. (Display shows 10SAFE)
Attempt 2 - wait 10 secs. (Display shows 9SAFE)
Attempt 3 - wait 10 mins. (Display shows 8SAFE)
Attempt 4 - wait 20 mins. (Display shows 7SAFE)
Attempt 5 - wait 40 mins. (Display shows 6SAFE)
Attempt 6 - wait 80 mins. (1 hr 20 mins) (Display shows 5SAFE)
Attempt 7 - wait 160 mins. (2 hrs 40 mins) (Display shows 4SAFE)
Attempt 8 - wait 320 mins. (5 hrs 20 mins) (Display shows 3SAFE)
Attempt 9 - wait 640 mins. (10 hrs 40 mins) (Display shows 2SAFE)
Attempt 10 - Time for the bin. (Display shows 1SAFE)
Username: Vinit
Ahmedabad, Gujarat India
Hi,
i cant understand about CD SAFE in type BLAUPUNKT 620 UP6 ..
MY REDIO IS WORKING BUT CD CHANGER IS NOT WORKING .
WHEN I TYPING THE CODE OF CD CHANGER THEN ERROR DISPLAY WHICH IS " CD SAFE "..
TELL ME WHAT CAN I DO?
i have code of 6 cd changer but how to enter it..
serial no. BP8386X0171444
Product code 92 057 949
Username: Hay88
Post Number: 1026
try this
to input your cd code "ignition on radio off hold 0
and switch on radio. ---- will display then press 1
repetedly untill the first number of your cd changer
code is in (not the radio code)
repete with 2 3 and 4. then hold 0". all done. hope this helps.
Username: Rodnai
Hello, Nissan 6 cd changer/radio PN-2649N when turned on reads (CODE IN) on display.
Username: Rodnai
Upload This is the PN-2649N
Username: Bursu
Somebody can help me with a code for my
Nissan Clarion PN-2649N
SN - CL066050012979
Please!
Tahnk you
Bursu
Username: Lukisgt
Please help me to, Iam Luki from Indonesia, i have Blaupunkt Type: CDC2 CD Changer at my chevrolet Zafira need code in CD safe,
GMCDC212572394
7 607 775 520
90 462 566
please help for my code
thankssss
Username: King0069
how do i bipass the pin i want to put the radio in an old car
Need to Register?
Forgot Password?
Enable HTML code in message
