Speaker Wire Gauge help
Username: Jacobfrank
I have 2 12" Alpine Type-R Subs (2 Ohm) with 600 watts RMS a piece running on a Hifonics Brutus BRZ1700.1D ]amp putting out 1200W at 2 Ohms. I am currently using 16 gauge speaker wire running from the amp to the subs, but found out recently that I need a lower gauge for that power. Would 12 or 10 gauge speaker wire be safest for my system?
Username: Angeljoe
Post Number: 22
I suggest to visit to carkart.com for speaker wire.
Username: Michael0107
Anyone need the Mazda silicone key cover,Nissan silicone remote key case and any other silicone key cover could find us,more info,welcome to visit www.trade-silicone.com http://www.trade-silicone.com
Username: Zara1200
You should change the wire of speaker.
Need to Register?
Forgot Password?
Enable HTML code in message
