Blaupunkt CDC A 05 wont work! pin code????
Username: Rachnrob
Gerringong, NSW
Hi, Had posted a thread earlier for the radio Pin code for a 1996
Renault Laguna. A code was posted and it works the radio fine
now, thou the10 stack CD changer (in the boot) wont work, it is a
Blauplunkt CDC A 05. Should there be a different code to work
this unit as well????? The option for the CD player comes up on
the display and you can change discs etc but you cant play a
track....Maybe the cd changer is just broken, but would hate to
throw it out if it wasn't and only needed a pin code!! Hope
someone can help me out with this, Many Thanks Rachel
Need to Register?
Forgot Password?
Enable HTML code in message
