Radio code for 54 plate magane cabriolet
Username: Flipper171
Hi, my battery died and my radio decoded itself. Any ideas on the code please? Thanks in advance
Username: Regrooster
Post Number: 6839
Sorry...this is insufficient information
The radio has to be removed from the dashboard
Then post the 14 character SERIAL NUMBER beginning with
RN* * * * * * * * * * * * found stamped in the metal casing.
Also post the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
