System WTF???
Username: Jordon32990
Hagerstown, IN
Post Number: 195
I recently bought 2 12" P3's used with a shitty 2600 watt boss amp.
The subs would play for like 2 minutes before cutting off.I've checked all the wires, they're alll good. All voice coils read out good.
After checking all of that, the subs wont play at all now. and the amp wont power anything, but its not in protect.....
Unless the amp is straight fried IDK WTF is wrong.
Username: Glasswolf
Post Number: 13845
you probably have the amp's gain set all the way up, causing the amp to clip and go into protect.
turn down the amp's gain to below half way.
Username: Nissankicker
Grambling, LA USA
Post Number: 307
The amp is prally HISTORY!
... Get you a better amp
Username: Waldroup1
I had the same amp and it did the same thing. But when mine did that it got ripped out and trashed.
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 15372
boss is low quality stuff im sad to say but make sure you have a 4 ohm load
