Port Tube Dimensions, i'm lost
Username: Samalbers92
I got a 15" lanzar for free and i decided to build a box, but i want to use a port tube not a vent and i'm not sure how to get the dimensions. Box is 3.29 cubic ft of air i want it 30 hz and vent dimensions are 3x13.25 and 14.5 long. Could i just take the volume of the manufacture vent and use a port tube with same dimensions? i know i'll prolly need more then one anyone have any idea how i do this?
Username: Domenico
BanginGMCArizona
Post Number: 460
what yr talking about is an aero port, and the vent you are talking about is a slot port. You should just stick with slot port.
Alrite i just figured droppin pvc in would of been alot easier it's a temporary box, thanks
