Background noise
Username: Surferdude9371
Get loud or go home....
Post Number: 1732
When i turn my volume all of the way down i hear a hissing noise very soft but drives me nuts does it on cd, radio, or ipod. ive changed my rca's, HU, comps, and amp any ideas?
Username: Van_man
Boston South, MA
Post Number: 4697
turn your gain down.
Post Number: 1733
thanks sir ill give that a shot
Username: Nd4spd18
Philadelphia, PA
Post Number: 10079
Re-ground HU to a good ground instead of using the factory ground wire.
I have found that 99% of noise problems can be solved either that way, or re-grounding the RCAs.
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 2774
What we do at the shop is run a drain wire from a screw on the back of the HU, to a screw on the chassis of the amp.
Seems to work everytime.
Post Number: 1734
hmmmmm thank you gentleman ill give both of those a shot im gonna finally finish my box tonight ports FINALLY arrived
Username: Hittin1
TEAM REVOLUTIONLake Charles...
Post Number: 2765
snake in dash? lol
I know, I know... but it has happened before. lol
Ready for vids and pics of new box and install.. like, ummm yesterday!
Username: Van_man
Boston South, MA
Post Number: 4709
well, some noise is expected at no volume, but if its exsissive, then check the gains. An amp will only amplify the noise. It could be rca issues as well as the HU as suggested .
GL.
Polo.
Username: Kickittothacurb
if you have a hissing noise in your sub, check for a pop noise when you put your car in park or neutral or reverse, if it does that, check your positive terminal on your battery, see how many volts are coming in. Other than that its the RCA's
