How Hard will 2 JL W7's hit ?
Username: Type94
Kitchener , Ontario Canada
Post Number: 57
How hard will 2 JL W7's hit and what amp will be best for them n i want to run them on full power ?
Username: Hurricanebr1an
Western Burbs of Chicago, IL Usa
Post Number: 556
HOW HARD??? SOOO HARD!!!
depends on size for power (duh)
10 - 400wrms
12 - 700wrms
13 - 1Kwrms
Username: 04redmach1
Columbus, GA USA
Post Number: 2008
They better hit considering the price :-)
What are you looking at exactly and budget?
Kevin
Username: Type94
Post Number: 58
Well budget is no problem and i want to max tem out using 13.5 inch JL's 2 of them .... will they be hard to beat on the streetz ?
Can they shake the windows of gas stations lol hahahaa ?
Username: Ctmike
Ct.
Post Number: 6204
oh god, what an idiot.
Username: Drant19
DUB-C, TX
Post Number: 1022
fraz, just buy them and find out
Username: Clouduz
Post Number: 351
lol...i hope you weren't serious
Username: Nd4spd18
Northwest PA
Post Number: 7603
" How hard will 2 JL W7's hit "
Hard, b!tch, hard like a rock, They're go-nnnnna make your azz go pop.
Username: Slivdogg
St.ignace, Mi United states
Post Number: 72
my buddie has 2 of them in his explorer and it knocks pictures off peoples walls and sets off plenty of car alarms
Username: Naledge503
LowDownForum.com
Post Number: 3840
^^thats bumping responsibly.....
A pic is worth 1000 posts!!
Post Number: 16975
Lol. It's nice to have the power to burp at the levels you want, INFREQUENTLY.
Who drives around at 80% volume anyways?
Coming from a home audio perspective the power from higher amps is best appreciated in SQ. How good does it sound at those levels is what I'm getting at.
For me when I was driving around with my system it was about hearing the music as intended at highway speeds, thus the need for power, not to bump pictures off ppl's walls.
Not that it isn't any fun when you can though.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 5357
it will pound so hard your ears are gonna POP LOL!!!!!!
Username: 94_toy
Post Number: 209
it will pound louder than 1 W7 and thats a big 10-4
Username: Nyyfan13
15 Mag USA
Post Number: 9825
"sets off plenty of car alarms"
Thats not very hard.....
Username: James1115
Use a simple...
Post Number: 10674
I am not gonna tell you it won't be loud because under normal circumstances they do get loud but what I can guarentee you is that for the money you can get louder.
Username: Evildoughboy08
james longo is right for what your gonna spend on these 2 W7s and probably a JL1000/1 amp you could just as well get 2 2008 15" L7s and beat the concrete with a JL 1000/1
Username: Nd4spd18
Northwest PA
Post Number: 7668
^^^^^ Hahaha when he said there is better he didn't mean L7s those sound like crap
Post Number: 9
L7s are amazing. your crazyyyy
Username: Bonhamd
TC, MI USA
Post Number: 751
they are not amazing. they get loud but they are cheap for a reason.
Username: Imi4tth3w
San Antonio, Texas USA
Post Number: 172
you'd probably need a jl 1000/1 per each 13.5 w7.
L7's suck. my friend got 2 15" with a jl 1000/1 on each and he can't stop blowing them. lucky for him his insurance payed for everything cause his old system got stolen.
Toledo, OH US and A
Post Number: 33
im glad for your friend. idk i havent ever had any problems with kicker, which is why i like them,
buuuuuttt...
i hear bad bad bad about them all the time. i used to have 2 15" l5s on a JL1000/1 turned up about half way and it sounded pretty good.
Toledo, OH US and A
Post Number: 34
nontheless, fraz.
if you get one W7 you will be happy, garunteed. get a JL1000 with it, though.
if you get TWO, you'll be ecstatic.
