Archive through February 21, 2006
Closed: New threads not accepted on this page
  Thread Last Poster Posts Last Post
Help with Alpine Interrupt LeadJohn Smith1
Simple Alternator QuestionOptidriven3
Few questions? Can anyone help?Seth Lowe9
Which would you choose?Seth Lowe8
Power wiringSeth Lowe11
The Big 3??Seth Lowe20
Simple Alternator QuestionGlassWolf5
Whine and a hum in my speakers and subsDan Antoniuk9
Why arent other pages working?Brett3
Will my jensen 12 hit 158db ?Pelon12
I fryed my altGreeney18883
Wire Diagram for Ford 2002 Expedition Stock StereoPaul Pena3
AVM-P8000RBally P1
Installing new cd/radio into 1998 hyundai accentChauncey Brown3
Stinger alternators?Titan BK1
Who makes a good battery isolator?Titan BK3
How do you get an alt out of a 89 accord? B5
Gold or plat. wires?Pelon7
What kind of box should I get?GlassWolf6
Which awg?GlassWolf5
PLEASE Someone HelpGlassWolf2
What the equation to figure out ampsGlassWolf5
Proper fuse rating for power wire on multi-amp setupGlassWolf11
Clean Bass SongsPelon24
Were can I get Free information on factory ampnyjavier1
Safest voltage to run alternator? Seth Lowe5
Hooking up 2 batteries in different parts of the car ?CadillacDb6
Eclipse ALTAudio_paul1
Upgrading help?B2
HELP with distrobution blockB4
For Sale Pioneer xm unit, direct link...ty mutlow1
GLASSWOLFE is da manAnonymous12
Should I get 2 new 12" CRV's or a high output alt. ?GlassWolf2
Is it OK to run 2 wires off of the battery for 2 amps?GlassWolf10
Car stereo converting to home "surround sound"GlassWolf2
About hooking 2 amps to 1 capjts1126
If a 200 amp alternator puts out 95 amp at idle is that normal?GlassWolf9
Favorite place to buy audio stuffBen Levine13
I have Mercedes Benz E classNight Mirage15
How about that? light dimming is not always a weak ALT, but a slow ...JL fan2
Just got HO alt!!matt8
How hard will it be to hook up my new alternator?Seth Lowe9
Wiring for a sirius base unit model no# SIR-STRVK1Stirling1
Whats better a deepcell battery or just 2 12V batteries ??Seth Lowe6
Is this ok 2 doSeth Lowe2
Check out this quote www.h-o-alternators.com gave me !!Terry640533
Sound deadening - Anyone use "Quiet Car?"Terry64052
No FM signalJames Longo2
Need to know how to get power?Isaac3
What should i do?Brandon4
8 voltsS.P.D14
Condensation!Brandon5
HO alternator QuestionsLee Viera8
I have a box for sale |\/|aTT |F11
Does this look right?Cameron4
??what is the cheapest HO alternator out there??Anonymous3
Coverting watts to amp drawOptidriven5
Isolator??? Pros and consIsaac5
Power problems, need second battery?GlassWolf13
HO alt/BatteryGlassWolf12
I need help please help meRyan Babendrager4
Seth LoweB16
HO alt/Batteryjosh meyer2
Adjusting Idle,,,,helpBrandon4
Alternate To New AlternatorOptidriven19
Subwoofer wiring Please HelpOptidriven2
How big in inches is a 4 gague wire wide ??Optidriven3
Sound Deadener ?scott DeBaker3
If my amp has a 60 amp fuse do i need a 60 amp fuse on my power cord??Optidriven7
Help on some wireingRyan Babendrager2
How big in inches is a 4 gague wire wide ??Anonymous1
Will 200A alternator be enoughChauncey Brown20
Can't find a HO alt for my carOptidriven8
How much is too much??Polo14
!! Total Meltdown !!Mitchell Stone4
What to use to cut and crimp 1/0 ga. wire?Seth Lowe6
Ground and Power?Mark Highland2
Soundstream amp problems?Eddie1
Wiring a cd deck?john f57
Install a alarm?B10
Post your stuff for saleB21
Upgrading electrical help. B5
Spray on Dynasheild? Worth it?Mitchell Stone3
NEW amp for sale!!Mitchell Stone2
Added another sub and system got quieterSeth Lowe11
Cap installationTyler6
Kicker Amp Kit : Direct Connect Engineering?Mitchell Stone2
Problem???Anonymous3
What capacitor size should be used is it 1 farad to 1000 watt'sOptidriven14
Does anyone know what is a good site to find a high output alternat...J-Dub3
Replacing the floor in the trunkReLOaDeD4
Gran vitara 2005Casey Wood2
Better Business Bereau Ratings?Brandon3
HELP ME GET A VIPER ALARMty mutlow4
Capacitor questionRESX122
Need help asap..installing this very minZulkir5
Wireing speakers to an ampblaine westropp2
Is it possible to install a laptop screen in a car as a tv???B5
Stinger power distribution blockB9
Best Alternator for the MoneyPelon8
