Neon wiring????
Username: Bass_fanatic
I have a bandpass box that also has a neon light tube inside of it http://cgi.ebay.com/Audiobahn-ABP10T-Dual-10-Subs-w-Box-Neon-Mirror-NEW_W0QQitem Z5845403065QQcategoryZ50567QQrdZ1QQcmdZViewItem
It has terminals for the positive and neg. wires. What's the best way to wire these and can i hook them up thru my amp?????Thanks!
Username: Slaya
Post Number: 16
I really don't know, and i'm just saying this off the top of my head but I really don't think its a good idea to wire a neon through an audio amp.
Username: Fandim
Reno, Nevada United State...
Post Number: 809
MTX - your best bet is to wire the input to your remote output of the amp, and you can ground it to the same ground your amp uses.
Be careful though, too many accessories off the rmeote output of your deck, and you'll blow it. If you are going to go this route, you should really get a bosch relay, and use yoru remote to activate the relay, and have a 12v from the battery to the input of the relay so it powers your accessories not the remote output. :-)
They can be had for about $2-$3 at any car parts store.
Seth
Username: Lincoln_ls_guy
Post Number: 16
I second Seth
