Need help
Username: Nypdlapd
Post Number: 50
My brother rewired his headunit and the ground and constant 12 volt wire touched.. but the wireharness was not connected to the H/U.Now the H/U does not turn on. what do i do to make it turn on??
Username: Nypdlapd
Post Number: 51
the Ground TOUCHED THE +12 VOLT
Username: Nypdlapd
Post Number: 52
Bump
Username: Cadillacdb
Houston , TX
Post Number: 625
blew the fuse in the car .. go to the fuse box an look for the radio fuse an replace it
Username: Nypdlapd
Post Number: 54
I did and it still does not work..
Houston , TX
Post Number: 626
Oh, i should have figured you would have already changed the fuse....are you sure he wired everything correctly ?
Username: Nypdlapd
Post Number: 56
it was a fuse
Username: Nypdlapd
Post Number: 57
no it only fixed the door lights but the radio does not turn on!! SHOULD I REPLACE THE GROUND AND +12 VOLT WIRE??
Username: B101
Queen City, NC USA
Post Number: 1654
u should check all the fuses, also the ones on the passanger kick too. sounds like u blew a few. the door lights and radio are on a diff fuse!
Username: Nypdlapd
Post Number: 58
It was a fuse!! i replaced the horn fuse and it started
