Will two caps make a difference
Username: Curious
Post Number: 48
Ok guys i have one bass cap that doesnt seem to stop my lights from dimming. the voltmeter is broke to but it still works right and will two caps make a difference because i don't want people thinking im flashing my lights at them even though its not that bad but its a bit annoying.
Username: B101
Queen City, NC USA
Post Number: 1374
it wont help, sounds like its already a bad charging system.... Get a high out alternator... www.excessiveamperage.com
Capacitor wont help much..
Username: B101
Queen City, NC USA
Post Number: 1375
http://www.glasswolf.net/caraudio/capacitors.html
http://www.glasswolf.net/caraudio/charging.html
http://www.betteraudio.com/geolemon/newmain/battcapalt/
http://www.bcae1.com/charging.htm
http://www.bcae1.com/chargin2.htm
http://www.glasswolf.netS/caraudio/batteries.html
http://www.the12volt.com/info/recwirsz.asp
Username: N2audio
Lawrence, Ks USA
Post Number: 668
what amps are you running?
how is your power wiring set up?
what speakers are connected and how?
Username: Curious
Post Number: 50
I only have one kenwood 9010d amp i think thats the part number and i have two alpine type r's with four gauge wire the subs are 12" and dual 2ohm voice coil they are hooked up to parralle/series amp sees two ohms and that is the least ohms it can see.
Username: N2audio
Lawrence, Ks USA
Post Number: 675
and the year/make/model of your car?
