Which amp???
Username: Goinglow
I'm looking at getting 2 Diamond Audio 12s D612D2/D612D4 (ohms depending on what amp im getting) But these are 600 watt RMS subs, and from what I've heard these should be an excellent choice. Anyway I get really good deals on Alpine MRD-M605 which puts out 600x1 RMS @ 2ohms, so I would run 1 to each sub. The thing is I MUST have 2 amps, 1 running to each sub, for design purposes. But let me know of my amp options here and what you think about this setup. Thx.
Username: Rovin
Trinidad & T...
Post Number: 5378
well if u have 2 use that MRD-M605 then its simple buy (2) 4ohms dvc subs & run 1 with each of that amp.
but i'd prolly buy (2) 4ohms dvc subs & use 1 amp like a PPI dcx 1500 or a Diamond D61000.1 , each does 1500wrms @ 1 ohm . Would sound even better & amp would have headroom so it'll run cooler ......
Username: Goinglow
Any other amps you might recommend since I need to run 2...and these dimensions on these amps are incredible...im going to be doing some hella fiberglass work
Username: Rovin
Trinidad & T...
Post Number: 5384
why must u have to run 2 amps ???.........
Username: Goinglow
Post Number: 7
show/design purposes...going to mount them on my rear doors need to keep everything consistent
Username: James1115
Ct
Post Number: 4932
jl 500/1's:-)
Username: Rovin
Trinidad & T...
Post Number: 5390
uh ok - then might as well match
2 Diamond D3600.1 amps with 2 4ohms dvc D6 subs ......
Username: Rovin
Trinidad & T...
Post Number: 5391
Whoooops - mistake above
i meant (2) 2ohms dvc subs with 2 of those amps .....
Username: Goinglow
Post Number: 8
thanks man i must of overlooked that amp on their site..now i jsut gota find out how many pairs of mids/highs to run
