I need advice...
Username: Sublime420
Ca Us
Post Number: 41
is the pioneer GM-3000T amp a good match for the pioneer 10" TSW250R sub? i known that stuff is not that great, but its for my moms car. she just needs a little thump, and i already have the amp from one of my old systems.
any input would be apperciated. what type of box, how big, what gages of wire do i need, is there a amp kit that would work, etc. (its going in a jeep grand cherokee)
Ca Us
Post Number: 42
anyone? please?
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 226
the 10" pioneer can recieve 120 rms .. u need to know the ohm config to select the proper amp
Continuous Power (4 ohm) 40W x 2
Continuous Power (2 ohm) 50W x 2
Continuous Power Bridged (4 ohm) 100W x 1
is the amps specs so u could prolly run the sub with it if u got a 4 ohm config .. these are single coil right?? wiring 8 gauge would be more than enough and i would go with a 1 ft^3 sealed wedge box.. u could do a ported box but u would need a bit more space and since its for your mom its prolly not a big deal..
Ca Us
Post Number: 43
exactly. thanx
