New wiring and sound shuts off after a few minutes (help)
Username: Tom55555
Hi. I just upgraded the wiring for my Panasonic home theater system with Monster THX 16awg speaker wires. Within a few minutes of playing my XBox (optical connection), the sound unexpectedly shut off... no warnings, crackling, error codes, etc. If i turn the receiver off and back on again, everything is fine but then sound cuts off after a few more min. I've triple checked all connections (+/-, signal direction, wires touching, etc.) and haven't found anything wrong. Any suggestions would be appreciated. Thanks in advance.
Username: Project6
Post Number: 5450
Signal direction??? Explain this signal direction!
Does the sound just cut off or does the receiver go into protect mode?
Username: Tom55555
Thought maybe this will help others out... I've noticed others below have the same problem as I had. When installing wires, I used Monster connectors (braided type) on the wire tips.. seems that was the problem. I removed the connectors and just connected the bare wires, everything is fine now.
