Surround sound newbie. Need advice
Username: Suff528
This will be my first experience with surround sound (newbie). My condo living room came hard wired with speaker wire. I would like to put in a 5.1 surround system. My budget is about $600. I would like to be able to connect my HDTV, xbox 360, Blu Ray, and laptop. I would also like to be able to control the volume with my cable provider's universal remote, so i don't have to use a separate remote for the volume.
Hopefully some one with some experience can point me in the right direction? Do you need any further information from me?
Thank you in advance!
Need to Register?
Forgot Password?
Enable HTML code in message
