Denon AVR 3808
Username: Red01
Hi all, Thanks in advance for your help,
I have the following equipment-
Denon AVR-3808 reciever
Pioneer PDP-506HDG - 50" Plasma
TIVO
Definitive Technology front and centre speakers and 4 x rear speakers
I will shortly be purchasing a blu-ray player with HDMI
I would like to be able to connect them up to achieve the following-
Watch TV without the reciever using the TIVO
Watch Blu-ray
I have it running now, but seem to have cables running everywhere to do it- optical, HDMI and normal cables
Because the Denon is programable, what is the best way to go with the cable- HDMI, optical?????
There has to be an easier way
Cheers
Username: Vm8444
TorontoCanada
Post Number: 406
dave watch tv without reciever?
I'm not sure in canada is
tivo a pvr?
why not hook up tivo directly to tv over hdmi
therefore sound will come from tv
or yes optical or coaxial cable will give you soon through speakers.
why?
theaudioguy.ca
Username: Nutpi
David, I would suggest you go with HDMI all the way.
Need to Register?
Forgot Password?
Enable HTML code in message
