Better home theater sound
Username: Nency
Post Number: 45
You've read put together a great home-theater system, but until you take some time to properly set up your components, they won't perform to the best of their abilities. We've assembled this checklist to help you quickly improve the sound of your home-theater system.
• Navigate the speaker-setup menus
• Buy a sound-level meter
• Confirm that your speaker and interconnect cables are in the correct positions
• Tweak subwoofer-level and crossover controls
• Purchase speaker stands or brackets
• Optimize speaker placement
• Tame uncooperative acoustics
• Upgrade speaker/interconnect cables
• Add a separate power amplifier
• Buy matched speakers
Username: Vm8444
TorontoCanada
Post Number: 294
Username: Petersteel
Yes you are right..my speaker is having the surround sound..and they went very well with woofers..
Need to Register?
Forgot Password?
Enable HTML code in message
