LG LHB335
Username: Sothereiwas
Ok, here is my set up. I have a HTPC running to my TV. I have the surround sound system mentioned in the title. I would like to be able to get the audio from the computer to play through the surround sound system. You can run the computer through the system but it only outputs very low quality (800x600). It looks horrible. Right now I have the PC running straight to the TV via HDMI and the surround sound running to the TV via HDMI. Any ideas?
I was thinking it would be nice if I could somehow split the hdmi signal. Video going straight from the PC to the TV and audio into the surround sound.
Username: Vm8444
TorontoCanada
Post Number: 287
Al hi,
forget the splitter you said,
does the lg system have any hdmi inputs then one output to tv?
or use this problem solved ,
site is good and safe
http://www.dakmart.com/p11034/SLED-DENON-AVR-1709-7.1-SURROUND-RECEIVER-AUTH-DLR-W-WT/product_info.html
theaudioguy.ca
It does have hdmi imputs and outputs. However when I run my PC through them it's maximum quality is horrible.
Need to Register?
Forgot Password?
Enable HTML code in message
