One HDMI to bind them all?
Username: Abe88
if I were to connect my 3 consoles to a receiver, could I then pass those signals to my tv with only one single HDMI out port through one single HDMI cable?
Username: Vm8444
TorontoCanada
Post Number: 230
hi lars yes with this reciever or higher model and it has 1.4 for passing a 3d video etc,,
lossless and all the other codecs not with optical but hdmi.
speakers are important
and wire too
http://www.amazon.com/Denon-AVR-591-Channel-Receiver-supporting/dp/B003H04Q8C
reads the reviews on these
http://www.amazon.com/Energy-Take-Classic-System-Black/dp/B001202C44
if you can't find them the energy micros are good for your room.
spker wire
http://www.crutchfield.com/p_703G250W/AudioQuest-G2-Speaker-Cable-50-ft-White.html
this is way below your budget, so bluray is a must too even 3d one. I'm interested in what you end up with.
theaudioguy.ca
Need to Register?
Forgot Password?
Enable HTML code in message
